JD 7520 Radiator
butch1203
My 7520 4wd radiator got ate by the water pump. does anyone know where to find one. I"ve been on the net for about 5 hours looking. thanks
butch
We had ours recored probably 15 yrs ago. I don't know where the radiator guy got the core. It has slightly less cooling capacity, but it's not a problem as long as you don't "push it to the limit". I have a manifold pressure gauge & the turbo will put out as much as 15-16 PSI max, but I don't usually run more than 10-12 under continuous load. With 16 speeds, it's not hard to find a gear that gives the desired load level. If you don't have a "boost gauge", I'd highly recommend installing one on your 7520.
That is a good idea. I've also thought about a pyrometer to see what the turbo is running at. thanks butch1203
