Josh in Pa
I recently bought a 920 moco with hydraulic tilt, that I posted about below. I am wanting to convert it from hydraulic tilt to manual tilt. With hydraulic tilt, the tractor should have three remotes, which mine does not. I thought it was a simple matter of taking the hydraulic cylinder off, and putting in a turnbuckle, but it appears that the brackets are different, and the manual tilt requires a weld-on bracket that changes the angle. I would think moving the bracket will change the way the head tilts as it is lifted. Is the additional bracket needed, and what does it do?
Josh
Josh
