JD LA WIIL NOT CRANK
Anonymous-0
I HAVE 1946 JOHN DEERE LA HAS BEEN RUNING GOOD PULLED IT OUT OF SHOP TO TRANSPORT TO SHOW AND WOULD NOT CRANK AGAIN CHECKED ALL FUEL RELATED ISUES GAS COMING TO CARB REMOVED PLUG WIRE FROM PLUG IT HAS NO SPARK I AM A NOVICE AND NEED SOME HELP FROM SOME OF YOU EXPERTS
Had the same problem recently and did clean up the points. I also put a little oil in the oil ports and now I have spark. Granted it isn"t the greatest spark (for whatever reason), but it should work.
