JD MC questions
Jim in michigan
I have a chance at a JD M crawler with a loader on it,hydraulic loader,not cable. It has a final drive bearing out and i think it had a bolt stripped in either the final drive or the track tightener,been a while since I looked at it,guy offered it to me for 800 yesterday,I am sure I could get it for a lot less maybe for 500,how much am I looking at putting into it for the parts I mentioned,are they available? Thanks,,Jim
Hi Jim. My first crawler was an MC. If you've seen it you know it is a 3-roll, pretty short for a loader. All Deere stuff new is expensive. I know/knew of a JD crawler scrapper in BC, Canada I got 420 parts from years ago.
yeah I know JD is pricey.and its just as old as my AC model M but a lot less HP then the M,cant afford to go newer so the old stuff has to do me. Jim
Hi Jim; If a bearing in the final drive is out and the crawler won;t move--alot of damage has already been done. when the bearing come apart, it falls to the bottom,the drive gear catches it carrys it around, no clearance in bottom case, breaks the housing out---everytime, may have wrecked the drive gear, [no longer available,]I've had some trouble finding used final parts. Early [53] 40C parts are the same, 420C are not. I have two 40C"s, MC ,and a 420C. I would however give 500 just to use for parts
the case isnt broken and it does move,I am unsure what bearing is out honestly, the guy is old and just wants to sell it,my 420 busted the final drive,took a lot of manuvering to get it on the trailer when i sold it,,Jim
An MC with a loader is marginal at best, they were rated at about 900lbs lift. The front idler is undersize, so all the stress goes on the forward roller. MC rollers are metal on metal, no bushings or bearings, so they do not tolerate this well.
If you want it for just the crawler, maybe not a bad deal, if you want a loader, look for a 420.
Lavoy
JDCRAWLERS.COM
I have a complete final drive off an MC for $500. I have some other parts also as I just parted out a couple but lots is gone. Located in Washington State. Joe 360-204-1017
