John deere 1010 dozer
The front coupler was proprietary from Deere (that bolts to the front crank pulley). All depends on which size pump you have. 1010s usually have a pump with splines that are 7/8" OD X 13. Ford and Case use the same. You can make a new coupler from Ford parts. The pump on the Ford, Case, Deere, etc. use a Webster or Cessna with a 2 bolt SAE B mount. Pretty common. I'm talking about a 1010 with a one piece drive before serial # 219,00. If you have a later 1010 with the pump disconnect - things are a little different.
You can adapt a Ford type coupler to work. I did it on my 1960 1010 crawler-loader years ago. Yous spines should be 7/8" X 13 just like these Ford couplers have. You might have to make an adapter plate to make it fit your crawler.
