John Deere 1010
67stepside
Hello,
Im working on a 1964 JD 1010rs. It has a severe leak on the left side where the PTO engagement lever shaft enters the case. Not a real big issues getting it fixed, its just a seal. But what holds the pivot shaft for the lever in the case? It appears the previous owner tried to weld it to the case and made a mess. I assume they were press fit but not sure. Its Item #59 on the breakdown below. Thanks for your help.
You must have the tractor split at this point? The torque tube is a dry compartment. It its leaking oil from there, its leaking from the hydraulic pump (if equipped), transmission, PTO gearbox, or the engine. Again, I assume that the tractor is split and you should be able to see if the pin, item #59 if a through hole is in the torque tube or if it is pressed in. I assume that it is pressed in.
Then again, assuming makes an a$$ out of you and me.
