John deere 1010
Wjt091
What is your opinions of this machine. And what do these machines go for. any info and opinions would be great. Thanks
Is it gas or diesel? blade type six way or straight? great machine, light
I wouldn"t use it to clean fence rows though.
its a hilift had fire in dash don't know what transmission owner said tracks were 50% going to look at it tomarrow motor is free any things to look for guys thanks for the help
Since it had fire damage, and you cannot verify how well anything works - anything over $1200 is too much in my opinion. It's worth close to that much as a parts machine. I bought a 1010 gas crawler-loader a while back and paid the guy $1500. It too had a light "hood and dash" fire. But, in this case, I knew the owner and knew all was working fine before the fire. Also, I've got a lot of experience as a Deere mechanic. That being said, that "light fire" damage wound up being worse than it looked. In most machines that I've had to fix, fire damage has always been worse than it looked.
You can find running 1010 crawlers in the $3000 range if you are patient and shop around.
I will add though, that the 1010 gas crawler is one of the best machines of the 1010/2010 series. As to having the reverser - it's nice to have but very expensive to fix. Pretty much the same reverser as used in the later 350s.
Also keep in mind that there's a serial number break with 1010 crawlers. Early 1010s with the gear shifter coming out of the dashboard use weaker transmissions from the 420-440 series. Later 1010s with the shifter down between your legs use the later 350 type transmission and are stronger machines.
Dont know where your at but come this summer i'll have a AC h3g for sale in IL. Runs good and is strong. I just have to get one hyd cly fixed on the loader.
I"ll be asking $6000. It runs great steers both directions great, rebuilt engine, and two main hyd cly are new. The hyd are tight no leaking and it has great hyd pressure.
