john deere 214 gets hot help!!!
Hoss357
any advice? mowed with it for the first time sunday and it got so hot started studdering? pulled plug a little white and extremely hot? is it running to lean? what should i do or how do you check? thanks
The carburetor could be set too lean, but it could
be something blocking the air flow to the engine, like a mouse nest, dirt or grass. Pull the fan shroud and see what's under there.
Hal
check the ing timing. If cam lobe or point plunger is worn seting point gap with feeler guage wont work. need to use a timing light.
