Anonymous-0
I have a 79 JD 2840 I just rebuilt the engine in. (New pistons,sleeves,main bearings,valves and injectors.) The injector number is an AR89564 and apparantly it goes in about ten thousand different applications sooooo, what I was wondering was if anyone out there knew what adjustments should be made to them before startup. The old ones were adjusted so that the lower locknut adjustment(spray pressure??) was screwed pretty far out, and the upper locknut and set screw adjustment (relief pressure??) was screwed about 90% in. The new, out of the package ones are just the opposite----adjust the same as the old ones, or run with it??? Thanks for your input and advice!!
