john deere 317 KT 17 24116A
Throw that engine away, no support and all were junk, bad oiling. Find a twin 18hp, think a "Command" model and it drops right in. OR, there are kits to put in V-twins available from Engine Warehouse or other places.
A command is a V type engine. The old engine was twin opposed. I think there will be driveshaft, exhaust and pto clutch issues to work around if a Kohler command is installed.
There was a thread on Weekend Freedom Machines on installind a Command in a 318, which I think is similar to your 317.
Check out small engine warehouse. They have a kit to switch your tractor over to a different engine. That series Kohler engine was bad new from day one. They had so many failures that Kohler could no longer afford to pay the warranties claims.
JD made a kit to pit an Onan in the JD 317 it contained the different shields and throttle cables and such. It was $1300 ten years ago.
The short block kit is. $2840
The complete engine change over kit is. $1350
This put an 18hp B&S in it.
Samll Engine Warehouse JD 317 page
