Anonymous-0
i just bought a john deere 4840 tractor it starts hard smoking extremely while cranking over could the injectors be bad? injector pump?turbo?hrs are unkown runs great after i get it started
(quoted from post at 20:11:13 02/13/11) Using the block heater when temps are below 40F ?
Has somebody hammered the pistons,rings and sleeves with ether?
(quoted from post at 11:06:42 02/13/11) First place to start is to adjust the valves.
(quoted from post at 08:27:42 02/14/11) are you suprised? 30/40 series are noted for poor starting and atrocious fuel consumption
(quoted from post at 14:22:26 02/14/11) So as long as everybody does it. Doing something questionable or wrong is ok?
A block heater is far more sense than pounding an engine with ether.
(quoted from post at 17:11:23 02/14/11) Some old timers say once they get used to the ether, its hard to stop. :lol:
(quoted from post at 00:15:24 02/15/11)(quoted from post at 17:11:23 02/14/11) Some old timers say once they get used to the ether, its hard to stop. :lol:
IMHO the reason engines get addicted to ether is broken top piston rings from from not injecting ether correctly according to instruction in operators manual. Ether is very similar to Brillcream "a little dab will do you"
