John Deere 50 pressed steel
Derek Young
Need help guys!! I have a John Deere 50 that I am looking at putting 9 bolt pressed steel rims on. I have the rims and tires just don't know what hub will work to mount them. Any advice is much appreciated!!!
Derek, one way you can do this is to find a factory dual hub set for a 4010. Then you can remove the wedges from your cast wheels and install them in these hubs and you have a nice setup. Don't try to use 4020 hubs as the taper on the wedges is different. The ones you want will measure 3 1/8" while the 4020 set you don't want measures 3 3/8". Hope this helps. Mike
Thanks a lot mike I believe that is the route I am going to take. Your help is greatly appreciated! Now I just need to find those hub for a reasonable price.
