john deere 60lp
Your 60 cam profile is the same as the 630, so dont waste your time swapping them. How much power do you need?
You would barely find the difference between stock and 125 over on a dyno. Sit down and figure the HP per cu" and the amount of cu" a 125 thou overbore provides.
Get a power-bloc, do some head work and install a Berry's cam.
Then again why is more power than stock required? A factory stock 60 will handle 6500lb on a clay track in 2nd gear.
There are three things to work on first before souping the engine. They are traction, traction and traction.
(quoted from post at 08:53:36 10/19/10)
I will agree that the extra power from the overbore will be hardly measaureable.
You are going to have to have a joke of a sled for a STOCK 60 to pull 2nd gear in 6500. I have seen a 60HP late A (same gearing as the 60) killed dead in its tracks by a good sled and good track at [u:1ac81a8254][b:1ac81a8254]5500lbs.[/b:1ac81a8254][/u:1ac81a8254], in 2nd gear. With a 7 foot long chain, it may hack it though.
(quoted from post at 20:09:51 10/18/10)
You are going to have to have a joke of a sled for a STOCK 60 to pull 2nd gear in 6500. I have seen a 60HP late A (same gearing as the 60) killed dead in its tracks by a good sled and good track at [u:01bb784b70][b:01bb784b70]5500lbs.[/b:01bb784b70][/u:01bb784b70], in 2nd gear. With a 7 foot long chain, it may hack it though.
Short 13.8X38 tires.
(quoted from post at 11:12:08 10/19/10)
You are going to have to have a joke of a sled for a STOCK 60 to pull 2nd gear in 6500. I have seen a 60HP late A (same gearing as the 60) killed dead in its tracks by a good sled and good track at [u:4498a69e12][b:4498a69e12]5500lbs.[/b:4498a69e12][/u:4498a69e12], in 2nd gear. With a 7 foot long chain, it may hack it though.
Even on itty bitty 13.6x38 tires a stock 60 will not run 6500 in 2nd gear on a good track with a respectable sled.
The A I was talking about was on uncut 16.9x34's with a 18" high drawbar. Put the little tires on, ADD 1000lbs to get to 6500, take away 33%HP to get to stock, A STOCK 60 isnt going to run 6500 in 2nd gear!
(quoted from post at 23:19:21 10/18/10)
You are going to have to have a joke of a sled for a STOCK 60 to pull 2nd gear in 6500. I have seen a 60HP late A (same gearing as the 60) killed dead in its tracks by a good sled and good track at [u:36b964e0c9][b:36b964e0c9]5500lbs.[/b:36b964e0c9][/u:36b964e0c9], in 2nd gear. With a 7 foot long chain, it may hack it though.
Looks like the old 60 at home has more snort than we thought.
this old 60lp of mine has now got 16-9 38s she has puled in the 9500 and got a 2nd out of 34 tractors we pull here in central e. tn.
