John Deere 6430P
gqjoe
Hi everyone. I just purchased a 6430 that I was told the intake preheater needs replacing. Just wondering where that is and or if someone has a tech manual and the directions to replace. Thank you
It is a grid type heater in the side intake manifold should have one big wire going to it . You will need the engine conf number to find the wright one. Some one on
here that knows what they are doing should be able to get a part pic for you
The cold start aid pictured below is shown in PC for 6430P European edition.
Thank you everyone for your help.
From what I found or thought the intake heater part number is RE530654 but I may be wrong. I will also continue looking.
Does anyone know of a reputable place to find a copy of the technical manual for the tractor?
Joe
Congratulations it appears you located the correct intake heater. I was searching under cold weather starting aid & I see it's listed under just "starting aid".
