Hugh McKinney
Okay, I took off the large nut on the right side brake drum, and after about a year, it finally got loose enough to separate the drum from the splined shaft. So I tried to pull the drum off...wouldn't quite come off. So then I removed the three large bolts that hold the whole assembly to the crankcase, no problem. I remove the splined shaft from the assembly, no problem. Then, again, I try to remove the drum from the brake assembly. Problem. I have tried loosening the shoe adjustment, still won't come off. Acts like something is just barely preventing it from coming off. Ideas? And if anybody gives me an "800" number, at this point, I'm open to anything. Thanks, Hugh
