John Deere 730 Hydraulics ?
Anonymous-0
was wondering if a wheel rake would work with a john deere 730 two cylinder tractor. Its a kuhn, and says it requires one double acting outlet with float position. Does a 730 have a float position?
There is a long "nut/cap" on the right side of the hydraulic box on the back. Unscrew it and it will reveal a slotted screw. Unscrew the screw and then screw it into the "nut" as far as it will go with the slot facing inside the "nut." Reinstall. When the hydraulic lever is pushed forward, it will stay in "float" position. Reverse the process to change it back. Good luck.
