John Deere A - Brake Drum
JD Michael
Thanks in advance for any advice.
I have a JD 1948 A, I bought in a junk yard to rebuild. I am down to removing the brakes, and I can get the brake assemblies out no problem, and they are both on the bench.
My problem is there is not a "nut" on the outside of the brake drum to remove it. There is a flat disc, about 1.5 inches wide, with three holes. One in the center, two on each side about 0.5 inches.
I cannot for the life of me figure out how to get the bloody drum off!! I took a punch to one of the holes, and lightly tapped CCW, but no.
Sorry, I am used to the G's, and the ones I have worked on all had a nut.
I have a 37 A if yours is like mine the nut is on the end of the shaft that holds the differental gear on.If you have the whole brake unit out on the bench loosen the nut and back off the brake adjustors hit the nut on a block of wood it should break loose.I think there is some with the nut on the outside of the drum but i cant rember witch ones, My buddie has a 52A and the nut is on the inside on the differntal gear.Hope this helps.
About the only thing that is different between the 48 "A" brake assembly and earlier is the cast iron housing inside the drum which is held on by three cap screws as opposed to the earlier housing which is held on by two. All other parts are the same and work the same and are dissasembled the same way.
Make sure all moving parts are free and cam operate. Move the adjusting screw out by turning it counter clockwise all the way. Loosen the castle nut at the end of the shaft, about four turns and using a piece of hard wood as a punch hit the end of the hard wood with a suitable hammer with the other end of the wood against the end of the shaft where the castle nut is till the shaft moves out of the pinion gear enough that the gear can slide off.
The shaft and drum should come out as one piece, so that the brake shoes can be serviced.
The brake drum does not come off of the shaft. You must remove the large nut and gear on the inside end of the shaft and pull the drum and shaft assembly out of the housing. If the brakes are rusty, this can be a bear of a job. You might have to heat the adjusters in order to back them off to get the bands to release.
BEFORE you try to pull the shaft out of the housing, check the splines to see if they have developed a 'flash' on the edges from the gear wearing on the shaft for 62 years. If there is a 'flash', take a file and remove it from each spline. Otherwise, when you push the shaft out of the housing, you will score/scratch/gouge the bushings which is not good. Once you get the drum and shaft assembly out of the housing, it should be pretty clear how they work and are adjusted.
Replaced the brake pads on "Old John" Nancy's 48A a few months ago.
Start by removing the entire brake assembly from the tractor.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Old%20John%20and%20No%205%20Mower/?action=view¤t=006.jpg" target="_blank">
006.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Remove the castle nut and washer from the shaft.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Old%20John%20and%20No%205%20Mower/?action=view¤t=007.jpg" target="_blank">
007.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Slide the drive gear off the shaft.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Old%20John%20and%20No%205%20Mower/?action=view¤t=008.jpg" target="_blank">
008.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Pull the brake drum and shaft from the brake.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Old%20John%20and%20No%205%20Mower/?action=view¤t=010.jpg" target="_blank">
010.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Now you can work on the brake pads.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Old%20John%20and%20No%205%20Mower/?action=view¤t=009.jpg" target="_blank">
009.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Hope this helps.
THANK YOU ALL, VERY-VERY MUCH, for your time and valuable help.
Such wonderful help. Very much appreciated.
Best regards to all.
These other guys make it sound easy and some are but some are really stuck.
If there stuck on there good loosen the nut and place a hardwood block on a concrete floor,then using the weight of the unit drop it nut first onto the wood while kinda supporting it. If it doesn't go at first drop it harder and it should pop loose.
