John Deere A front hubs....
Low96hb
I am looking to find out what all casting numbers will fit a late styled John Deere A. the set I have is too short and I have to turn the wheels around backwards ( with the dish out ) so they won't rub.
Low, first of all you will need to know if you have Roll-O-Matic on your tractor. The wheel flange on a ROM hub is more or less centered on the hub. A non-ROM hub has the wheel flange very near the cap surface. It sounds as though you got the wrong hub. Mike
Sorry... It is not a roll a matic. and the hobs I have has the wheel flange near the center. I have found a couple of sets, but I was just wontering before I spent and money...Thanks LOW
There are 3 diff sets that will work. With the FLANGE near the CAP, for winter and MUD use. The middle FLANGE for REVERSE RIMS , such as JD-1258R on ROLL a MATICS and the FLANGE close to the SPINDEL for unstyled tractors with no REVERSIBLE RIMS with 11 consecutive RIVETS that hold the CENTER to the RIM. Also 8 rivet rims that had rivets spaced increments of 2 in 4 places, also none reversible.
I have found a set of A3004R that has the flange near the cap. will those work with the wheel that is dished inward?
Also, check for cracks on the stud holes. I just changed front tires
on my 50A (Rollomatic) and one wheel had over the years gotten
loose, I assume, and there were cracks on three holes. We braised
them and ground back and they are OK.
Low,
The A3004R hubs are correct for the non roll-o-matic front end.The A3479R go on the roll-o-matic.
The correct rims are JD1268 .
Rich Duane
