john deere AR main seal.(flywhee.
Anonymous-0
I have a bad leak behind the flywheel.I removed the flywheel and the the flywheel spacer and seal. The seal had a shoulder on it. The replacement seal does not.The new seal appears to be the correct size to fit the deepest groove. Is a replacement seal available with the shoulder? Does the replacement seal need to be cut to get it installed in the recessed groove in the spacer?
