My Dad left me an early-styled JD-B 'project' and - with help of this forum - I have it mostly back together, I got it running, and now I have more questions!
1) Hard to start. I am getting the hang of it but would welcome a how-to (at what part of the cycle do I start the big spin?)
2) Backfires. I get backfires from time to time when trying to start it. I thought I was dead the first time it went off.
3) Oil splatter from flywheel. It seems that the flywheel spreads oil droplets (forms a line on the ground and coats the left brake). It isn't clear whether this happens all the time or just on startup, but it makes a big mess.
4) Lots of smoke. My dad had worked on the carb and I'm sure it needs tuning now. I turned the closest tab out (left) and it ran better (before it would only stay running with full throttle, now a bit more of a range). Still lots of smoke.
5) New bowl valve doesn't stop tractor. Dad had bought a new fuel bowl, and I connected it direct to the big tank (no more gas/fuel/off switch). But when I turn the bowl valve off it doesn't stop the flow of gas entirely... so I have to choke out the tractor and then drain all the gas.
I'd welcome your input and advice on any of the points above.
I have a video of it running but I don't think I can load that here - I can share separately.
Thanks in advance JD friends
