I have a 1948 JD-B, it sat in a yard for a decade. I resurrected it with a new carb, new ignition, spark plugs, and other parts. The engine had collected a fair amount of rain water over the years. I changed out all the lube. It only ran on a single cylinder for the first few hours, and then the other came alive.
She smokes pretty badly and blows oil droplets out the exhaust stack. There is an intermittent engine rattle that accompanies heavier puffs of smoke. It sounds like a penny bouncing around inside the cylinder. I suspected maybe pitting on the cylinder bore from rain water running down the exhaust, or maybe a damaged piston ring.
I did a compression check on the advice of the forum, and she did surprisingly well. 140# on the right and 130# on the left side.
This is how she sounds:
https://youtube.com/shorts/uHmBPgXWxDY?feature=share
Droplets of oil spray everywhere from the exhaust stack.
How is oil migrating from the crankcase and out the stack with apparently good compression? Is it sneaking through the valve train somehow?
