john deere compression adapters
njfarmer
i am trying to do a compression test on a John Deere 9500 combine. i already pulled the injectors to have them rebuilt and would like to check to compression to make sure that there wasn't any damage since i had 2 bad injectors. They are the Bosch 21mm style where you have to use the special 15/16 socket to pull them. Does anyone know where i can buy a compression adapter?
Try your local tool truck dealer, for Snap on, Mac, Matco, etc. Or go to HF, and buy a kit, with the right adapter, in it.
I thought the Harbor Freight kit would have it but it only comes with 10, 12, 18, and 24 mm adapters. Bummer.
Aaron
Your dealer, unless you would find one on ebay, but I looked the other night for jd tools, not much listed. They might even let you rent/borrow one if there is one. chris
i saw that one earlier but i don't know if its the right one because that looks like it is for flange mount injectors when this one is the screw in style. This is the injector that i took out and want to find a compatable adapter that is like it.
http://www.spencerdiesel.com/Detail.asp?Part=SDNRE25253
