John Deere grain drill
Zane McGill
I bought a John Deere grain drill and would like any tips on moving this planter. I would like to pull it home behind my truck. I think it is a 10' - 13 hole drill. It has a fertilizer bin, seeder, and planter bins. It does not have a cylinder to lift(It was not originally equiped with one). There are two hand cranks on the front, do these lift the double disk openers? I need to raise everything so that I can pull it home. I don't see any trip levers or any way to raise other than maybe these hand cranks. Any suggestions or information would be appreciated.
Thanks!
if it's an end wheel drill take along plenty of wire or rope to tie the openers up so they don't touch the road, had a JD pda press that lifted high enough but some didn't
If its an early unit, it should have a chain driven trip mechanism or 2 to raise and lower the openers. If its newer, it may have a hyd cyl that may have been removed, look to see if there is a lift mechanism with no cyl attached. If this is the case, you can lift it with a screw type cylinder, or a spare toplink. If it has the older mechanical lift, it can still be lifted by putting a big (18-24") adjustable wrench on the bigger of the 2 square shafts, and pulling upward on the wrench, then chain it in place for the trip. The model # should be on a tag on the right end cap of the drill box, as you look at it from the front. Post that, and you can get more info.
Cranks only limit depth drop, to have the cranks it has to have l lift lever for connected to a rope like a clutch lift plow and there would be a lever for each crank. The cylinder lift models set the depth with a cylinder stop. Then there was the one like mine that had 2 lift levers and there were different notches the pawls fit in for setting the depth.
It's probably similar to this drill in pic but there were others with hand cranks a bit different. Like others said you should have a lift clutch with trip lever to lift it. If it's broke try lifting it with jacks or come along and look for a transport lock to hold it up if has that. If has gang press wheels take them off and haul those. Grease the end wheels well if going far and take the drive chains off by the each end wheel. The openers got a cotter key on the rods for depth adjustment just move it so they all lift higher. You can drop the rods out and take springs off and put rods back in lift holders to raise higher too. Definitely worth it to have it all right and locked and lifted high enough so not having to stop along the way.
If you pull it on the road, you have to make sure the discs are high enough so they don't drag on the road, especially on a road that is curved up in the middle, as most roads are. I have done that on my own driveway where the wheels would go down part way on the shoulder of the road. There is a cast iron piece between the discs that will break from the vibration when this happens. I have welded a couple of them because of this. If you do this, you must go very slow if the discs are rolling on a hard road. I also had a John Deere model B drill.
