Anonymous-0
I just aquired a JD "M" had not run for about 2 years. gas was drained when shut down. checked tank appeared good and clean. replaced plugs wires points condenser rotor cap. put in new gas. tractor started right up but would not idle. pulled carb off(tsx245) model and done a rebuild on it. also done compression test with engine at running temp 115 each cylinder. tractor still will not idle. runs fine from about 1/4 throttle to full throttle.also checked timing (ok). what am I missing. open to all and any idea's.
thanks in advance Butch
