John Deere MC crawler
JD Rookie
Hi all,
I am trying to get the sprocket hub off of a 1952 JD MC. The manual I am using shows a nut on the end of the final drive axle. My crawler does not have a nut on the end of the axle. Any help would be greatly appreciated.
IF there is no nut on the axle, someone has either welded the hub to the axle, you do not have an MC, or someone has swapped a later final with the one piece axle in place of the original.
Lavoy
JDCRAWLERS.COM
Thanks for the info, as I did more research last night I was pretty sure I wasn"t dealing with a MC. When my grandpa died the appraiser listed it as a 1952 MC, that was what I went off of. I have the hood and radiator guard but it hasn"t been on in years. No serial tag or other way to identify it. It has a two cylinder motor, five rollers on the bottom of the track, tracks extend all the way to the front weight. I"m thinking it"s a 40C, 420. Any easy ways to distinguish between the two of them. As I said I"m new to this and the pictures I"ve seen haven"t given me a enough confidence to go out and buy another shop manual. Any help would be appreciated.
If the shifter has a cage to align you with the gears it is probably a 420. If it has a long shift handle with no cage then a 40.
I have two 420 crawlers. The '56 4-speed doesn't have a cage. The '57 5-speed does. I know the '57 has never been changed since I bought it new and because the '56 was in the family of the dealer til I bought it I don't think it was ever changed either.
First of all I would like to thank everyone for all the help. Now my final questions. The crawler has a cage to align you in the gears. I has a short slightly bent shifter. It has a 5speed plus reverse transmission. As far as the Water pump goes I'm not 100% sure, Was it built into the engine block with about a 1 inch hose returning up the top larger hose coming out of the radiator? I believe I am dealing with a later model 420C. Again, all the help to this point has been terrific, and I would have been really lost with out you guys.
Sounds like a 420. I don't believe the 40 had a 5-speed transmission, while the 420 had a 4 or 5. The shift handle is bent to clear the clutch handles.
