John Deere MT Water Pump Question
Where the heck is it? I just got a 1951 John Deere MT and I took off the cowling and the nose piece today. I have 1 belt that runs from the crank to a pulley and off that same pulley a belt that runs the generator. There is of course a top radiator hose off the top of the raidator that connects to the top area of the head and the bottom radiator hose that connects to the side of the block.... but nothing goes to a pump. I am not getting any circulation of water because I just drained it and I would get green water... then brown water, then red water, then back to clean water. When I ran it earlier today the top of the raidiator was very hot and the bottom not so... Anyhow..... Any ideas? I dont consider myself to much of a noob since this is my 7th tractor, but it is my first 2 cylinder.
Any help would be greatly appreicated.
Thanks,
Craig
no water pump,works on the principle that hot water goes to the top,cool to the bottom.so your hot on top,cool on bottom is correct.dont trust the tractors temp gauge,on early M's they had it in the hottest part of the coolant manifold.Use a known working thermometer to be sure when checking the coolant temp. bill m.
Be SURE to thoroughly mix the coolant BEFORE you put it in the radiator. The MT has no water pump and, as stated, uses thermosyphon circulation. Water and antifreeze have different specific gravities and make it hard to circulate unless pre mixed.
Also make certain that your water level is set as stated in the JD service manual. Since it is using the thermo syphon principal, too full or too low and it does not work as well.
I just got done putting new antifreeze in my MT, and it did not take 3-1/2 gallons as stated in the manual. I just got a little under 3 before it was full, and then bubbled out when I ran the tractor. It is still full above the tops of the tubes, but it definitely does not have 3-1/2 gallons in it now...
Did you go back with the double rubber hoses and original length metal pipe with a slight bend on the bottom (return)? Did you have the radiator repaired or core replaced?
