I just encountered something I would not have believed if I had not seen it myself.
I have a cabin in the Adirondacks with off-grid solar electric. It's a 12 volt DC system. There are also two 3000 watt inverters to make AC. The cabin has two wire systems throughout. One part has outlets and lights that are 12 volts DC. The other part has outlets and lights that are 120 volts AC.
I mention this to explain why there are three service panels. One for DC, one for AC with mod-wave inverter #1, and another panel for sine-wave inverter #2.
Panel one is tied to the ground system (two 6 foot rods ten feet apart). The other two do not have the neutral bonding screws installed. So, I guess panel one can be loosely referred to as the "main panel."
This system passed inspection although the inspector did scratch his head a bit.
Now - here's what just happened.
My 12 volt DC lights are wired up with standard AC components. 10 gauge Romex NM cable, standard boxes, HD snap switches, etc. The only thing slightly special is the panel is Square D type QO. I had to use QO since it's one of the few AC panels that is also rated for DC (along with the breakers.)
To make this long story shorter . . . one of my lights had a 12 volt CFL bulb that worked fine. But - I just got some 12 volt LED bulbs and decided to try one. The reason being that LEDs can handle being turned off and on much better then CFLs.
So, I screwed in the new LED bulb. I then noticed it glowed dimly even when turned off. So - my first assumption was that the AC wall switch did not perfectly breaking current when used for DC. So, I unhooked the switch. Guess what? The LED bulb was still glowing dimly with only one wire hooked to it ! I did not think it was possible to make a bulb work at all with only one lead hooked to it. It was the negative lead, by the way. I checked voltage at the bulb when glowing and read 169 millivolts. Seems an LED bulb can glow a bit with extremely low voltage.
To fix the problem, I did this - but it was a lucky guess. I went down to the DC electric breaker panel and installed the bonding screw into what would be the "neutral" bus bar if it was hooked for AC. For DC, the "neutral" bar is for negative. So, shorting the negative bus bar to ground made the bulb go out. I checked amp flow at the bonding screw and it was .005 of an amp.
Here's the bulb with only one wire hooked to it:
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0242s.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0235s.jpg" target="_blank">
</a>
DC wired panel (Square D rated DC and AC)
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0243s.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0227s.jpg" target="_blank">
</a>
RMS voltmeter showing 169 millivolts to light when "off" (ignore reversed polarity)
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0240s.jpg" target="_blank">
</a>
Amp reading through bonding screw that shorts negative to ground - showing .oo5 if an amp.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0228s.jpg" target="_blank">
</a>
Switch box with switch removed and light glowing as shown:
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_0239.jpg" target="_blank">
</a>
