jose bagge..horse walker help
Anonymous-0
Well I ripped the old walker apart. Trans is leaking but probably OK. Vertical car/truck differential is locking up. Guess i have a gear off the pinion or ring gear. Question, do you know how to pull the pig out of the differential if the axles can't be pulled out like a car differential? If the spider gear is welded to the carrier on the bottom, and the top axle , which is the mast of the walker, can we repair the ring gear and pinion? I'm ready to give it a try but would sure appreciate your advice.
