Geo-TH,In
I have 2 questions. 1. Is the cam follower pin pressed in or threaded? My pin has about 1/8 inch wear and so does 2/3 of the cam where the rubbed against. Dealer doesn't have a pin. Thought I may make one on the lath. 2. There is a small plate on top of the lift cover. It is located on the back left corner. CNH dealer thinks this plate could be removed to add more hyd. When I removed this plate there were 4 o-rings. Dealer couldn't find any o-rings. Are o-rings required or did someone add them? Should I add some kind of gasket sealer to this plate? Thanks for your input. George
