Just bought a Case 480 CK
Rob Ratch
Hi,
I just bought a Case 480 CK to do some yard work. THe seller knew very little about the machine itself.
Could anyone tell me anything about it by it's serial (I assume this is the serial):
5002960
The machine doesn't run right now as the distributor is in pieces. The seller thought it had a Ford motor, but the little info I've scoured off the web and through a tractors parts dealer, Case didnt use Ford motors.
The engine model number is G1488.
I'm wonder what year this machine is, and where I can find parts and other info about it (like a repair manual, and operating manual)...
Thanks in advance for any help!
Serial nrs for 480 CK tractors at the link below. I think the gas engine is a 148B, built after 1960, shares some of the same parts as the older 148 cid but has larger crankshaft journals.
Joe
serial nrs
your local dealer can get you the books you need the serial you gave was that off the tractor or motor or loader ? the one I need to tell you the year should be on the right side of hood close to the tach this is as you are setting in the seat top should say 480CK below this will be serial # on some models this tag was on RH side of steering column
Yup, it was on the right side, kind of tucked behind the loader controls.
I don"t know what that other serial I posted was, it must have been for the loader.
The serial from the p-late you pointed me to is 8661570, which makes it a 1970.
Thanks!!
Ah, yes it must be a 148B. The label is shot, so it looks like 1488.
Thanks, that should help with getting the ignition parts.
