Just noticed something on this forum
Dozer Guy
I just noticed this , I useally use the modern view, but for kicks I switched over to classic view and noticed that the classic has more replys than modern and they are different than the modern ones... Has it always been that way ? Look at sparktricians post and see if its the same way for you or is it only on my computer... WHY is this ??? larry
(quoted from post at 16:54:19 12/09/08) I just noticed this , I useally use the modern view, but for kicks I switched over to classic view and noticed that the classic has more replys than modern and they are different than the modern ones... Has it always been that way ? Look at sparktricians post and see if its the same way for you or is it only on my computer... WHY is this ??? larry
Same technology was used voting machines for the elections. Everyone got to vote, but the counters used the modern view for McCain and the classic for the other one.
YES WE CAN!!!!!!!!!!
I've been noticing it off and on also. Don't know why it is though.
Dave
Top right corner of the page. If you are in classic view, there is a bar across the top and a "modern view" icon on the far right. If you are in modern view, there is a box in the top right w/ a bunch of icons (one of them "classic view")
Dave
It's not supposed to do that, they should always be the same but we'll have a problem sometimes and then the two go there own way. It happened today. For several hours there was a problem that disconnected the two sides. Normally I can fix it so the modern catches up, but today it actually lost the posts.
Chris
Is there a benefit to the classic view (connectivity issues)? So much more user friendly on the modern view.
Dave
With dial up service YT classic/original format runs fast and without a hitch compared to more "modern" formats with all their smily faces and whatnots that pop up and run around. Same reason I like old machines because they are simple and work is why I like this old forum.
I use the 'classic' view only because it loads that way on every computer I use. If 'modern' view came up first, I would use that instead. I'm just lazy I guess...
