I have a new to me HT20 with a K482 (must be a replacement engine). It was given to a friend of mine several years ago because the driveshaft came apart and damaged both rockshafts. It's been sitting outside for about 5 years and I just acquired it. Thankfully it was free.
I got the motor running and it runs very good but the top end is super clattery. I have an 1886 with a K482 and the top end noise on the HT20 is very noisy in comparison. It runs smoothly through the rev range otherwise, although I didn't run it long. It doesn't smoke or knock.
I changed the oil and filter. I checked the oil pressure and it was about 100 pounds at idle initially and then slowly started dropping. Shop temp was in the 30s at that time. Again, I didn't run it too long, the oil pump is obviously working. I removed the valve covers and ran the engine again. My concern is I don't see oil flow in the valve boxes but I'm not that familiar with these engines. It sounds like the clatter is closer to the geartrain, not the tappets and valves I don't believe.
I'm just looking for some thoughts and/or direction. Thank you.
