Kawasaki fuel pump
Russ from MN
Location
Bemidji MN
Today I checked the oil in our Husqvarna lawn tractor with a Kawasaki V-twin, and it was over full. Is it posible for the fuel
pump to leak gas into the crankcase when sitting? The gas tank is under the seat, but I did have it pretty full so maybe it
just drained through the carb. Any ideas?
yes I have seen it leak thru both, vacumn pumps usually not very its carb but have seen it lots on the mechanical pumps a lot. still trying to get shop closed out.
Although it is possible for the fuel to leak through a hole in the fuel pump diaphragm, it is much more likely that the fuel leaked past the needle in the carburetor and filled the engine.
