kill switch
You might try an outboard motor or atv/4-sheeler dealership. A lot of those type vehicles have them. mike
(quoted from post at 05:38:21 02/15/10) You might try an outboard motor or atv/4-sheeler dealership. A lot of those type vehicles have them. mike
That is what I would use. I don't think a trailer one would be as good for a pulling application.
The one I am most familiar with it the bottom one on the link, but I think the double ball would be REALLY easy to install. You could mount it to the rear of the deck and then just hook a small cable to that for the sled operators hook to go to. If you drilled out the hole/did a hair more fabbing you wouldn't even need a wire.
http://www.cpperformance.com/products/Electrical/switches-ignition-kill.htm
This topic has been discussed many times on the pulling board, search the archives. I use a trailer break away that I got at TSC. They are heavy duty but keep in mind that they complete a circuit when pulled. What I did was wire to each side of the coil. I don't know how right that is but it kills it right now. Don't plan on using it that often anyhow. You can get one for a boat that can be wired either way, normally open or normally closed. Any boat repair should be able to get one cheap. I have a friend who just used an extention cord with another plug end wired as a jumper that could be unplugged when pulled. It "mysteriously" got loose and came out going down the track so I got him a marine one. What ever you use just make sure it works.
