Knowledge shared
MSS3020
In my short life as a "weekend/evening farmer" I have discovered some things that I have modified on my tractor to solve some issues. So..I want to know "other" modifications, solutions, etc. That others have made to make things a tad bit easier.
Couple things ..Draw bar on my 3020 gets oval over time..creates slop. After welding it back true, found a bushing to stick in the 1" hole to make a 1/2" hole when I bale or rake. But can take it out for use with my swather what needs 1" pin. Also draw bar top has worn over the years before I got her. Welded it up, ground smooth and use a large washer between the baler tongue and drawbar as a cushin.
Looks like we wern't alone in repair of draw bar holes and re welding the worn down slide/ Used A.c.D.C. welder with 7013 rod. Came back as good as new. LOU
