Kohler engines
Anonymous-0
What is the expeced life (hrs.) of those Kohler two cylinder engines they put on the large lawn mowers? Do you rebuild or replace?
You can rebuild, kohlers are very durable. We had one on a JD rebuilt it after 25 years it was still running when we baught our new one the tractor is now 31 years old the young guy that has it mows 5 acres. But its not a cheap job even if you do it yourself. Regards, John
I have "heard" through a buddy that worked at a small engine repair shop that the new Kohler twins will easily run 2500 hrs. if they have been given any kind of maintainence. At that point, they are typically rebored and rebuilt.
Kohler twin KT17 early series has got a minor reputation for short life- weak lower end/splash oiling not good enough, side tilting meant low oil- possible broken rod, especially if user didn't have full crankcase. Later twins with full pressure oiling corrected problem. RN
Saw that price in the new Northern Catalog. I was thinking I paid A LOT LESS than that for a Troyblt with a 19 horse Kohler in it??
