large allen wrench?
ChrisLSD
what is the name for those huge pieces of 6 sided allen wrench that you can put on a ratchet -
I have a couple oil level check plugs that are rusted shut (my bet is it is low on oil) - looks like a drum bung with the threads on the outside...the head of a 1/2" bolt fits in perfectly - i tried welding a nut on a grade 8 bolt - but it twists off easily -
Is this what you need?
you"ve answered your own question.
Allen wrenches are available in many sizes, from
mini, to over an inch, and larger, from the tool
trucks- Snap-On, Matco, Mac, to Crapsman, and
auto parts stores. In the "L" shaped version, to
ones with 3/8, 1/2, 3/4 drive sockets.
I SAW A CHUNK OFF A ALLEN WRENCH, DROP IT IN A STD. SOCKET.
I ALWAYS SLIDE A PIPE OVER THE REGULAR ALLEN SO SHORTEN THEM DOES NOT MATTER.
My 2 sets of them,made by Wright,are 3/8" drive and 1/2" drive.The 1/2" drive goes to 1/2". Never needed any size larger but I would think Wright could furnish any size you needed up to the max size commonly used on consumer products. Industrial and commercial is another game.Would a hard bolt with double nutts on the shank with a head that would fit the Allen Screw and a long handled Breaker Bar do the job? I've used rigged up combinations like that before.
