Need some help on putting Larson LED's on a John Deere 4440. I am putting the option #3 lights all around the tractor. The PAR-36 lights fit into the tractor's original light housings. Eight lights in total with each having 1700 effective lumens. Plus I did put Tiger Lights 3 light LED kit in the front end cap. Should make a very noticeable change I hope. The problem is when I get the new LED's wired up and begin to push it into the original fixtures it seems like I can't push it in far enough to get the three tabs to pop out front to lock the light in. Always can get one tab. Push harder and get two, but to get the third tab you have to stick a screw driver in and forcefully bend the third and sometimes second tab out. After all three tabs are outside of the light the housing appears to be slightly miss shaped. I have not tried soaping the surfaces yet to see if that helps. Also thought of using a blow dryer to warm up the plastic/rubber light fixture some. Anyone else had this problem?? Talked to Larson Lights and they say the light fixture has been exposed to sun and heat many years and probably has shrunk up some. The people at Larson Lights I feel are very helpful, honest and forthright. Product is a good value. They recommended the lubricant (soap). I know some of you have used these PAR-36 LED lights and wondered if you had problems and what you did. Thanks. Other than that the conversion went well and I think I will have somewhere around 17,900 lumens of light.
