Late A axle housing
IAMIKE
Is it possible to swap a square axle housing onto a round axle tractor? One A is a '49 the other is a '52. The later one is in bad shape, the earlier one has a cracked housing. Was hoping a swap might work.
I wonder if I will have to change bull gears though? They are taller in the '49 than in the later tractor.
Just an observation. Unless my eyes are cheating me. . .which wouldn't surprise me any. The casting number of the rear end housing is the same, A3270R. I have the '49 apart, so I guess now is the time to try it.
I verified that the bull gears are indeed the same. So I think it should work. I will let you know on the outcome.
I know it will work, as i have done it bolts right up be sure to get gasket from deere don't use gasket maker as it may move the the bull gears to far into the drive gears
