I have the breather tube coming out of the block, then the tube in the picture, then the cap. The threaded stem had a piece of rubber hose running to the ground. I don't see any place for the rubber tube to connect and I haven't found it in any books/pictures. Did someone bypass the breather cap? The breather cap is to small for the tube coming out of the block. Maybe someone scavenged it off another tractor? It wouldn't be the first part I found that didn't belong on this tractors. What is the proper inside diameter of the oil breather tube?
Thank you all for the help!
