laziness can be dangerous!!!
Anonymous-0
Got a HF quick hitch for my little tractor that has been the best thing since sliced bread. Can't pull a water trailer with it mounted so have been using the front end hitch to move tanks. Trailer weighs more than the tractor by a few hundred pounds which is no biggy if hooked to the back.
Had to put a tank in place where I had to go uphill a little yesterday and couldn't go backwards (spinning), went forwards pushing the trailer and was OK til I had to back up a little. Trailer pushed the tractor, jackknifed and rolled both frt tires off the rims and I have a big booboo on my frt cap. Guess I'll be welding a hitch to my fast hitch.
The kicker is, it takes all of 2 minutes to take off the fast hitch and put the normal trailer hitch on.
Dave
Beat ya to it.......... but not sure if it'll work. Hitches here are a little different (pintles that pull just above the axles) Not sure if I can lift the hitch high enough. That will be my 1st choice. If it works, I'll post a pic of the "rig".
Dave
