Anonymous-0
Just had a guy say I didn't need to run lead replacement in my 1967 Farmall 706 Have been since I got it was always told if its older than the '70's that you should looking for your opinions.
(quoted from post at 12:40:27 10/01/12) In case you havent noticed NASCAR is using ethanol just like you get at the pump
Correct.... As of the 2011 season, the three touring NASCAR series (Cup, Nationwide and Truck) use Sunoco Green E-15. Before that they used what was basically leaded blue aircraft gas.(quoted from post at 06:40:27 10/01/12) In case you havent noticed NASCAR is using ethanol just like you get at the pump
