Leak on JD8630 transmission front output U joint
John 680
Got a leak on the transmission front output U joint (location is in rear part, at torque divider lower output to front differential). In order to replace the seal and eventually the ball bearing I would like to know whether the shaft of the U joint can be pulled out of the torque divider without having to separate the tractor or not (i.e. will there be enough space / length in the hinge area). Thanks in advance for a feedback and any advice on how to proceed.
