Leaking poly tank
GordoSD
Some time ago we had a discussion re how to fixfarm tanks. No one had a real solid answer.
I have been dealing with a sprayer tank on my ATV that cracked at the threaded insert mount pad.
I tried about 5 different things, silicon, JB Weld, RTV, plumbers putty. Nothing worked.
Two days ago I tried a tube of the "Seal All" gas and oil resistant contact adhesive from Wally World. It flowed right over the area, dried in about an hour. Applied a second coat.
Yesterday I filled up the tank, parked it on the driveway slab, and VOILA, not a drop leaked out.
Gordo
Last year I bought a sprayer at an auction. Refitted the booms and plumbing and found a broken fitting on the bottom. An outfit in town builds plastic tanks, so took it in hoping they could patch it somehow. A guy came out with a router and a plastic cap or plug. The router had a special fitting on it to spin the plastic plug. About 3 seconds of the router spinning and the two plastics melted together and job done. They put plastic fitting onto tanks the same way. Very impressed.
Congrats on the repair, im guessing it may not be permanent, after that I have found that the only way to repair poly is to heat weld it.
The only way I have fixed them when they do that, is replace the tank with a plastic 15 gal drum without the inserts they do that all the time.
