Lesson from DOT
Deano4863
Hi Guys,
I got a warning today from the DOT because my 2" ratchet straps where outside the rubrail. They are outside the rub rail because the hook on either end will not pass through the rail, it's too big. Officer was kind enough to show me how to dissassemble the straps and pass them though the rail to get me legal.(duh on my part, never occurred to me). This is kind of tediuos as I now have to get under the trailer with the ratchet end to get a place to hook to. Rather than replace straps with newer flat hooks can I heat and bend the existing hooks a little flatter? Will doing that affect their strenght?
I wouldn"t heat and bend the hooks. I"m assuming you have the wire hooks? I use ratchet straps that have a short length of chain at either end. I never liked the way the wire hooks hooked onto the rub rail. One possible solution to avoid buying new straps would be to be the chain ends and hook your existing straps to them. Try and Ancra number 43366-12 or 43366-14. Eventually, I would try to buy new straps.
I've had the straps outside the rub rail many times and never had a complaint. What is right and what is wrong all depends on which officer inspects you and how good or bad his day is going.
Never heard that this was a problem for them. OK, it's outside the rub rail, but it's in no more danger there than it is running over/across the object your hauling. I had a truck stopped by the other day to pick up a couple of items for me and the straps on his load were inside and outside the rail just depending on what was loaded and how the strap had to run to effectively tie it down. As far as the DOT guys in general I love the way some of them can keep coming up with something new to hassel people over. I think most of them just get their jollies messing with people because they really have nothing better to do. Not saying all of them are like that, there are good and bad out there, I know, but just in general.......
Would not mess with the hooks. Get you a wedge of wood and drive behind the rub rail to move it out a little....unless the hooks would force you to make a really big wedge.
if you read the law concerning securing loads, you'll see that it states that straps are to be run on the inside of rub rails. The reason is that if you sideswipe something with the trailer , the strap won't be cut off. They are called "rub rails" for a reason.
Get a copy of the little green and white FMCSA rule book. If you are CDL you are supposed to have one with you in the truck. Lots of good info in there.
(quoted from post at 14:49:38 01/04/10) if you read the law concerning securing loads, you'll see that it states that straps are to be run on the inside of rub rails. The reason is that if you sideswipe something with the trailer , the strap won't be cut off. They are called "rub rails" for a reason.
Maybe you could reference where you found this. My cargo securement manual says not required in the USA but required in Canada.
I see nothing in the G&W book about inside or outside.
I live just outside Houston TX. This is the second time this Texas State Trooper has stopped me. That is just my luck as I rarely haul anything and was bringing home some lumber from the lumber yard. The 1st time I had used 3 straps to tie down a 9n ford and shredder. He explained to me at that time that I had to use chains and binders and that the chains had to be inside the rub rail. He did not write tickets either time.
It talked to a commercial flatbend driver and he explained that this was common knowledge and that it's the law accross the country.
I just know that this trooper is looking for me and I appreciate the education without the fines. My knowledge of cargo sucurement came from the farm in rural Iowa. I have never lost a load. But that doesn't mean I have been doing it "right" all these years.
It wouldn't hurt to bone up on the books, but the feds don't require chains. FMCSA requires simply that there be sufficient restraints rated at sufficient capacity to secure the load. Straps, chains, rope . . . If Texas really does require chains, then you need to bone up on Texas regs, as well.
Truth to tell, I suspect he's sniffin' around tryin' to catch you over 10,000lbs and operating commercially without a DOT number.
Another good idea is to attach ratchet end of straps ( or binders w/ chains)on passenger side of bed, you won"t be in the traffic lane tightening loads on the side of the road
Modifying the tie downs is also forbiden. I remember reading on here, someone got ticketed for having his ID welded onto the handle of the over-centering locks for a chain. While that would not in any way affect the strength of the tool, it was a violation.
Obviously, things had gotten a little out of hand on _that_ stop, but anyhow - heating & bending the clamps would be an infraction, if pressed.....
--->Paul
The rules for new trailers over 10k says it must have appoved manufacturors tie down points and a sticker stating what those points are rated at.So if rub rail is not rated no can use anymore.
Yes, the lawyer for the party suing you will gladly point out that YOU changed the manufacturer's hook strength by heating and bending the hook. DO NOT, under any circumstances, alter the manufacturer's original design on anything.
If what you buy does not work for you, buy something else, but do not alter the manufacturer's product ---- because by altering the product, you assume 100% of the liability if something goes wrong. It just ain't worth it!!!
It doen't really make sense, because on the out side of the rubrail isn't any worse than if you did not have a rub rail. We have flatbed trucks at the farm I work at and we have some with and without rub rails. All have rollers for straps but not all have rubrails. So the guy with rubrails gets ticketed for not using them. Doesn't make much sense to me.
Can someone please provide a link for where we
can get a copy of this little green and white
book, or for that matter any good reference on
tie down particulars across the country? I
have a six ton Landoll flatbed trailer and am
new to hauling things. Thank you much
The link below is to the FMCSA regs, Part 393. You have to scroll down a bit to get to Subpart I, which deals with cargo securement.
393.100 - 393.114 are general (but critical) information for what can be used and how to tie down. The rest, .114-.136, deal with the specific requirements for different kinds of cargo. In particular, .128 deals with vehicles weighing under 10,000#, and .130 deals with those weighing 10k or more.
You can also get hard copies of the books from your state DMV.
HTH
Part 393
(quoted from post at 10:53:55 01/05/10) The link below is to the FMCSA regs, Part 393. You have to scroll down a bit to get to Subpart I, which deals with cargo securement.
HTH
Part 393
And do you see where it says anything about inside or outside the rub rail: which was the OPs original issue.
The green and white book can be bought from J.J. Keller. They also have a Cargo Securement Manual which explains all the tie down regulations in easier to understand language. Napa also carries the Cargo Securement Manual and it cost less than J.J. Keller.
No, I do not.
The quoted post was in reply to Butch's question, which is relevant to the OP's original issue, as well as the one raised in his own followup post.
(quoted from post at 20:17:43 01/05/10) No, I do not.
I wonder if "inside the rub rail" is a Texas thing???
Could well be. I don't see anything in the Federal regs on it.
Other possibilities (where it's not all that bad an idea, really) that come to mind
a) it's a good suggestion that might make it into some states' CDL books,, even though it's not a reg.
b) if a diesel bear really wanted to push it, and the trailer's rub rails were a whole 102", he might claim that you're operating overwidth without a permit. (As far as I know, the only thing that can extend beyond 102" are mirrors on the tow vehicle, and maybe a few things like side mounted turn signals like on the old cab-overs) Or at a narrower level, the hooks outside could throw the whole thing over 80" which opens up all the lighting and conspicuity requirements.
o
old friend of mine who had trucked all his life told me one day as i was boomong down a tractor that any thing out side rub rail made you load a wide load, any thing past edge of bed is a wide load needing a permit.
(quoted from post at 21:02:16 01/05/10) Could well be. I don't see anything in the Federal regs on it.
I do believe you are correct if the trailer is a 102, back in my days on the road we had 96" flats and 102" box units.
Setting the tie down inside the rub rail is the easiest any way, my old flats had round bars in them so the chian pulled smooth over a radius. Even with straps the hooks go over the rub with strap behind the rail so it don't come off when you go to tighten it.
I did a little more looking after I saw this question over on the Tractor Transporting board, and it appears that tie-down apparatus is not counted as width, unless it extends 3" or more beyond the edge.
Part 658, App. D
