Let's talk cub starters
grandpa Love
Cub we bought a couple weeks ago has starter issues. When we first got it the starter was sparking and ground to a horrible death after a couple turns. My wife took it off, tore it apart and cleaned it good. It was amazingly clean inside. She used some emory cloth and cleaned it good. After she put it back on the tractor crunk up about 5-6 times then the sparks returned and it stopped again. Tapped it with a hammer handle and it spun a couple more times. Should we order a re build kit? It was easy enough to do. The brushes in this one aren't flat but have a pretty good angle on them. Any tips? Thanks.
Did she clean out the slots on where the brushes run. They have to be Groves in them to make it work. I have use an hack saw blade with one end cut off so u can cut the Grove out some. Try and make them all the same depth.
Are the brushes in good contact with the commutator, as in long enough that the springs are holding them tight down against it?
If they are worn too short, new brushes might fix it IF the armature is not shorted internally.
A shorted armature will usually show as a pair of commutator segments being heat discolored, darker than the rest, solder slung out where the winding is soldered to the end. If that has happened it will need a new (used) armature. If the brushes are short they may have rapidly burned away because of a shorted armature.
How sloppy is the fit between the bushing in the end plate and the armature shaft? When you have it apart again put the end plate back on the shaft and see how much it wobbles. The bearing in the front plate might be sloppy also. I have taken an alternator apart that the bearing allowed the armature to make contact with the stator. It was one ugly alternator inside.
Where is it sparking, at the brushes?
Is the cover band and gasket for the brush area missing or just off for testing purposes? (Once you get it repaired it needs the cover with gasket to keep rain and debris out of the starter's innards.)
As a "heads up", emery cloth isn't recommended for cleaning up commutators (IF that's what she's using it for) ordinary sandpaper is what is usually recommended. I believe the reason is that any debris left may be conductive, plus it's tougher to clean off completely so none remains to wear the brushes prematurely.
You can copy the link below and paste it into your browser to view the official IH Blue Ribbon Electrical Service Manuals.
http://farmallcub.com/rudi_cub/www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/index.html
Did you check the switch on top of the starter. Mine did something similar and they replace the brass contacts on the starter motor
