I have an old heavy 7' Ford back blade on the back of my 202 Massey Ferguson. I recently rebuilt the entire 3 pt hitch system including pump and all internals for the lift and adjusted it properly. I was trying to level out some new gravel on the driveway and for the life of me I can't seem to get it all level without ups and downs. I tried numerous different settings for the draft control and blade position but every time the front wheels dipped into a low spot the blade would momentarily pop off the ground and create a high spot. And of course as I graded more the problem got progressively worse.
Now I figure the draft control should be able to react quick enough if set properly so that the blade is pretty much always in the right position but for some reason this doesn't seem to be happening.
So how do you guys do it? How do you set things up, what speed do you run at etc.?
