lift failure, Ford 3000
The lift on my Ford 3000 has been a bit erratic for the past few months. It would lift a full load, but would not work at first. Then it would drop the load, lift it up again when the lever was raised. It would not hold a constant position, even when the engine was running. I changed the fluid with no different results. The fluid was milky. Now it will not lift at all. Any ideas? Thanks, Joe
You have water in the oil and most likely rusted up control parts. You may want to remove the deck, clean everything up and replace the gaskets and (O) rings.
Did you prime the hydraulic pump after changing the fluid? The 3000 has an external mounted hydraulic pump. Pull the coil wire so the tractor will not start. Remove the allen head plug on the pump then turn tractor over until a steady flow of oil (with out air bubbles) is coming out. insert the plug while still turning the tractor over. YOu should be good to go after that. Good luck.
Check your draft lever position lever as well. My 3000 is very erratic in draft control but holds well in position control.
