Light a fire under it?
well I tried something today I didn't think I would ever do....start a fire under the Case to get her started....Cold weather ,wind and snow, make it hard to start , finnaly got her going and plowed out the 3' drifts in the drive and got some ether to get her going next time. We have more snow coming tommorrow and the next day.spent 2 1/2 hours plowing , warming up now , gotta go out and feed the critters now that my feet are warm. Everybody stay warm now. Shawn
Best and by far the safest way to do it is to buy a coolant type heater for it. But of course even then they can be hard to get started but safer then a fire by far. A tarp and the coolant heat go a long ways to help one start and even a light bulb by the manifold if its a diesel
Hobby farm
We used to slide an old metal pan filled with hot charcoal under the engine on a car that was sitting outside in the cold. We never did start one on fire but you should have seen the sparks fly if you didn't pull the pan out before you started it and the wind from the fan hit it.
I didn't ever invision having to do the fire thing , and I have used light bulbs in the engine bay of cars before , along with tarping , but the tractor was in a area that a tarp was not going to stay (Wind was whipping 20+ MPH,and the temps were in the single didgits) and I no longer have a salimander . i think the can of starting fluid should do the trick from here out , just watched the weather and they are calling for 3-8" my X-mas with a low of 6 and high of 18 tommorow and a chance of rain/sleet on Xmas eve, and rain and 50 by friday....if you dont like the weater , wait 15 min and it will change , not always for the better tho...
I bought one of those LP salamanders, 44,000 btu per hour model, someone had it on craigslist, along with a compressor that I bought as well.
Left my LP powered tractor outside, right after the icestorm here, no start, put a tarp over it, set that unit underneath, away from the tarp, was connected to a 20lb bbq tank, about 20 minutes later, she fired up, took awhile to warm up, stalled out once, LP was freezing up, but 2nd time left that tarp on there, heat on again, that was it. I then kicked my car out of the garage, put that tractor in there, no more cold starts, that little heater cost me $40, works great, just have to always remember it's an open flame, my LP fuel system on the tractor was rebuilt, no leaks, same with other fuels, without it, it would still be there with these temps lately.
Yep,
A drip pan 'bout half full of #2 diesel fuel works just right. Started 'em that way for many years.
#1 fuel doesn't work; way, way too hot and too much flame.
Allan
A hose/pipe installed over the exhaust pipe of a donor vehicle routing the heat/exhaust underneath the oil pan of the engine to be started is a far safer method than the fire method...............another method is to add heat directly into the intake manifold while cranking(diesel only)via a small propane torch, this method tends to work better on N/A engines due to less heat loss in the intake system...........
Shawn: I hope this case was a diesel. Never do this with a gas engine, and only on a diesel if you have no fuel or oil leaks. Charcoal is the best. I used charcoal for years in a cast iron fry pan, used to sit right under oil pan of 6 cylinder Deere. You can boil the oil.
Billy,
If in the winter you would shut the fuel off on you LP tractor and run the engine until it runs out of fuel when you are done with it. Then the next cold morning open the VAPOR valve to start the tractor, your vaporizer will not freeze-up. When you have the tractor up to tempature you can then open the LIQUID valve and close the VAPOR valve.
Kent
Why would anybody take the time,effort,risk or expense? To build a fire under a machine, use tarps/burners and burn high priced fuel to mostly heat the great outdoors with a little on the tractor. Or risk damaging the engine by manually spraying ether into the intake?
Just get a cheap simple reliable coolant heater. Plug it in and use a few cents worth of electricity and she starts like summer time.
No open flame, no tarps flapping in the wind. No broken piston rings. No extra strain and wear on the starter, battery,generator/alternator.
http://www.phillipsandtemro.com/UserFiles/File/ZEROSTART_Catalog_WEB.pdf
we are in northern wisconsin and gets mighty cold, but have to start diesel trucks and tractors for an auction lot. we have 4 of those magnetic heaters. STick them on the oil pan or a flat spot where theres water on the other side. works great and you can use them for many different engines.
Back in the old days you got by with what you had . Kerosene and a bucket of corn cobs after the kero burned off you had red hot coals . And very rarely anyone ever caught anything on fire.
friend almost burnt his dozer up doing this. Bunch of leaves caught & set oily twigs on fire, which caught more debris. Barely got it put out at the cost of a new jacket his wife had just bought him. Happened 40 yrs ago & he hasn't heard the last of it yet.
A good safe way is to warm up enough oil to do an oil change. Get it VERY warm. Drain the old oil the night before. Pour in the warmed oil and hit the starter.
4 feet of 6 inch stove pipe with an elbow on the end under the oil pan of the tractor with a tarp over the hood and put a propane torch in the end of the pipe. the elbow acts like a chimmey and the flame is 4 feet from the tractor. It is amazing how much heat it will put out and you don't have to have it roaring either. I started my A farmall that way one winter every time I had to plow snow. When it got warm it wasn't too hard to crank. Bud
40 yrs ago at a rock quarry that I worked at the boss used a can of either and a lighter to heat up and thaw out everything. Scared me.
It was around 5F last week when I tried to start my Ford 4610. No go.
A friend lent me an oil fired torpedo heater and after an hour of it blowing on the oil pan and block, my tractor started right up. I fed the cows and then took it to a neighbors heated shop where I added a block heater. Starts on the first turn after ~3 hrs of being plugged in.
Don't build a fire under it. You're liable to burn it up. See if you can find a block heater for it or use a an oil or propane heater. It's safer.
Had my Oliver 1650 froze up today. Got out the electric heat gun and used that on the fuel lines, sediment bulb, pump and bottom of the tank
by the sediment bulb. That got things thawed out enough for the tractor to start and the heat from the engine to take over and keep things flowing. A lot safer than using a open flame.
Of course, I can't find a picture, but it must have been common over here to use a smudge pot looking thing to preheat equipment from tractors to locomotives. I saw one once a few years ago at a flea market.
Dave
Who lives in the city?
The guy who started this posting wrote it in 2008, it isn't a time warp message from 1949.
For where there is no electricity there are LP coolant heaters. Or just get a little generator and plug the coolant heater in. It's still cheaper & safer than lighting a fire or using ether.
Any of you see a problem lighting a fire under a machine built in the last 30 years. Most have plastic, fiberglass components, paint you care about, electrical wiring or hydraulics? It's not a model D John Deere with a massive expanse of cast iron chassis and little else.
Dorking around with farmer fixes which take longer, cost more, are less effective, take more work and risk damage. Instead of using a economical and readily available coolant heater? That's just plain short sighted foolishness.
A 1500W or 2000W tank heater will heat an engine from stone cold to starting temps faster than any blaze set underneath. Or portable air heater blowing against the exterior of the tractor.
When my dad has had to start any tractors during the cold, he got away from fire pits under the tractors (not the smartest thing under a gas tractor!)and Bought a Karosun heater, set it on low with a few 2' sheets of plywood as a windshield, and starting was easy.
I had an AC D-14 freeze completely, because the dealer rebuilt it but was too cheap to put in ANY antifreeze. I went to start it on the coldest day I can remember. It fired right up, I started smelling the burning belt, shut it down immediately, looked it over to see what if anything was froze and busted. Turned out that the thermostat housing(aluminum) and 3 freeze plugs on the head were all that blew (grand total of $13.75) I thawed the rest of the water out by putting a perfection (wick type) kerosene heater under it(the tractor, that is), and ended up with about 4 barn cats on top of it!
I remember my Dad had a hog pan filled with hot coals from the cookstove.He put this under his 34 Ford on subzero mornings.He used to put a blanket over the hood and used a small kerosene heater he bought from the Western Auto under the hood.It looked like a lantern with a steel chimney.Warming the battery helps.An old mechanic told me about tow starting cars that had 140 gear oil in the rear ends.He said the tires just slid along the snow covered roads.I remember seeing my Dad, Mother and Aunt,pushing an old pontiac out of the driveway.Once on the road there was enough down grade to push start the car.My 96 pickup had trouble starting at 8 below a few days ago.New battery last year.
