Like to double hyd pump output
circus
How could I double the hydraulic pump output on a Leyland 270? Would like to replace the original pump inside the differential housing. Do able?
Would be easier, generally speaking, to run a new pump off of the front of the crankshaft (front of motor). Trying to replace a factory sourced pump in the diff, would be a daunting task.
Yes there is a new style of pump for the Leyland 270. Just installed one on customers tractor a week ago. I got it from Fawcett Tractor Supply Ltd. Phone number (519) - 284-2379 they are in Canada. Here is the part number you need to order ATJ6597. this is a hyd. pump kit.
